Component: CAN Bus BL0140 (E-blocks 2)
(Redirected from Component: ID af9061e8 7f2b 475e 844f 66ab76823d07)
Jump to navigationJump to searchAuthor | |
Version | 1.0 |
Category | E-blocks 2 |
- 1 CAN_Bus_BL0140 component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 ChangeRate
- 5.2 CheckRx
- 5.3 GetRxData
- 5.4 GetRxDataCount
- 5.5 GetRxIDHi
- 5.6 GetRxIDLo
- 5.7 GetRxIDSimple
- 5.8 GetRxIdent
- 5.9 Initialise
- 5.10 ReadSwitches
- 5.11 SendBuffer
- 5.12 SetRxFilter
- 5.13 SetRxFilterID
- 5.14 SetRxMask
- 5.15 SetRxMaskID
- 5.16 SetTxData
- 5.17 SetTxID
- 5.18 SetTxIDSimple
- 5.19 SetTxIdent
- 5.20 ShowLEDs
- 6 Property reference
Please click here to download the component source project: FC_Comp_Source_EBlocks2_CAN_Bus_BL0140_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_CAN_Bus_BL0140_2d.fcfx
ChangeRate
ChangeRate | |
Simple attempt to alter the bus rate of the CAN. External CAN channels only, | |
- BYTE | Rate |
Rate: 0-3 where 0=125, 1=250, 2=500, 3=1000 | |
- VOID | Return |
CheckRx
CheckRx | |
Checks to see if any messages are available for 'Buffer' specified | |
- BYTE | Buffer |
Send buffer: 0 to 1 | |
- BYTE | Return |
GetRxData
GetRxData | |
Returns last received message data byte at position Index. Buffer parameter is currently ignored | |
- BYTE | Buffer |
- BYTE | Index |
- BYTE | Return |
GetRxDataCount
GetRxDataCount | |
Returns last received message data length. Buffer parameter is currently ignored | |
- BYTE | Buffer |
- BYTE | Return |
GetRxIDHi
GetRxIDHi | |
Gets the Hi byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous, | |
- BYTE | Buffer |
Receive Buffer. Range 0-1 | |
- BYTE | Return |
GetRxIDLo
GetRxIDLo | |
Gets the Lo byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous, | |
- BYTE | Buffer |
- BYTE | Return |
GetRxIDSimple
GetRxIDSimple | |
Gets the Rx ID as a Integer Standard ID only 0-2047. | |
- BYTE | Buffer |
- UINT | Return |
GetRxIdent
GetRxIdent | |
Gets the Rx ID as a Integer Standard and Extended IDs. | |
- BYTE | Buffer |
- ULONG | Return |
Initialise | |
Must be called before any other CAN component macros to enable and initialise the CAN peripheral. | |
- VOID | Return |
ReadSwitches
ReadSwitches | |
Returns switch input states from the external MCP2515 device. 0 = No Switch Pressed, 1 = Switch 1 Pressed, 2 = Switch 2 Pressed, 3 = Both Pressed (External CAN only) | |
- BYTE | Return |
SendBuffer
SendBuffer | |
Transmits one of the transmit buffers which should have already been populated with an ID and data. | |
- BYTE | Buffer |
Specifies which transmit buffer to send | |
- VOID | Return |
SetRxFilter
SetRxFilterID
SetRxMask
SetRxMaskID
SetTxData
SetTxID
SetTxIDSimple
SetTxIDSimple | |
Set the Tx CAN ID as a generic number. Standard IDs only 0-2047. | |
- BYTE | Buffer |
Transmit buffer to load. Range: 0-2 | |
- UINT | ID |
The ID value you wish to use. Range: 0-2047 | |
- VOID | Return |
SetTxIdent
ShowLEDs
ShowLEDs | |
Set LED state (External CAN only) | |
- BYTE | led1 |
Controls LED 1. Range: 0-1 | |
- BYTE | led2 |
Controls LED 2. Range: 0-1 | |
- VOID | Return |
