Component: Electrical Machines (AllCode)
(Redirected from Component: ID c3e5eb13 e03d 4ca6 be4d 1c63ad107a35)
Version | 2.0 |
Category | AllCode |
- 1 Electrical Machines component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 Get3PhaseMode
- 5.2 GetAPIVersion
- 5.3 GetAbsPosition
- 5.4 GetCommsOK
- 5.5 GetControlFeedback
- 5.6 GetControlOutputs
- 5.7 GetCurrent
- 5.8 GetDataArray
- 5.9 GetErrorStatus
- 5.10 GetLogData
- 5.11 GetLogDataReady
- 5.12 GetLogStartAngle
- 5.13 GetMotorDirection
- 5.14 GetRPM
- 5.15 GetSafetySwitch
- 5.16 GetVoltage
- 5.17 GetWeight
- 5.18 Initialise
- 5.19 SetAbsPosition
- 5.20 SetActive
- 5.21 SetCapacitorBank
- 5.22 SetControlKD
- 5.23 SetControlKI
- 5.24 SetControlKP
- 5.25 SetControlMaxDrivePercentage
- 5.26 SetControlSetpoint
- 5.27 SetDriveMode
- 5.28 SetDynoLoad
- 5.29 SetFan
- 5.30 SetFrequency
- 5.31 SetLoadCellCalibration
- 5.32 SetMotorDirection
- 5.33 SetMotorType
- 5.34 SetTCPProps
- 5.35 SetThreePhaseDriveMode
- 5.36 SetVoltage
- 5.37 ZeroLoadCell
- 6 Property reference
A set of functions to communicate with the Matrix EM hardware. Allows the functions to be easily standardised across all SCADA programs.
Please click here to download the component source project: FC_Comp_Source_EM_Functions.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_EM_Functions.fcsx
Get3PhaseMode
Get3PhaseMode | |
Checks to see if the brushless mode is enabled | |
- BOOL | Return |
GetAPIVersion
GetAPIVersion | |
Reads the API firmware version | |
- BYTE | Return |
GetAbsPosition
GetAbsPosition | |
Reads the absolute position of the encoder | |
- ULONG | Return |
GetCommsOK
GetCommsOK | |
Checks if comms are ok and stable | |
- BOOL | Return |
GetControlFeedback
GetControlFeedback | |
- FLOAT | Return |
GetControlOutputs
GetControlOutputs | |
- FLOAT | Data |
- VOID | Return |
GetCurrent
GetCurrent | |
Reads the current of a single channel | |
- BYTE | Channel |
Range: 0-6 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=Dyno, 6=I, 7=TotalDriver | |
- FLOAT | Return |
GetDataArray
GetErrorStatus
GetLogData
GetLogData | |
Gets a 64-byte packet of log data. 250 packets make up a single log. Returns 0 if comms failed and 1 if comms OK | |
- BYTE | Buffer |
Buffer to store the incoming log data | |
- BOOL | Return |
GetLogDataReady
GetLogDataReady | |
Checks to see if the logging is complete and ready to read. | |
- BOOL | Return |
GetLogStartAngle
GetLogStartAngle | |
Collects the U Phase angle at the start of logging. Used to calculate and re-create the 3Phase voltage data. | |
- BYTE | Return |
GetMotorDirection
GetMotorDirection | |
Reads the motor direction | |
- UINT | Return |
GetRPM
GetRPM | |
Reads the speed in RPM | |
- UINT | Return |
GetSafetySwitch
GetSafetySwitch | |
Reads the safety switch | |
- UINT | Return |
GetVoltage
GetVoltage | |
Reads the voltage of a single channel | |
- BYTE | Channel |
Range: 0-5 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=VEXT | |
- FLOAT | Return |
GetWeight
GetWeight | |
- BYTE | Scale |
Range: 0-1 - 0=Weight, 1=Torque | |
- FLOAT | Return |
Initialise | |
Returns 1 if the connection is ok and communications have been established | |
- BYTE | MotorType |
0=DC, 1=1Phase, 2=3Phase, 3=AngleControl | |
- BOOL | Return |
SetAbsPosition
SetAbsPosition | |
Resets the absolute motor position to 0 | |
- VOID | Return |
SetActive
SetActive | |
- BOOL | Active |
0=Off, 1=On | |
- VOID | Return |
SetCapacitorBank
SetCapacitorBank | |
- BYTE | Cap |
- VOID | Return |
SetControlKD
SetControlKD | |
- FLOAT | Value |
- VOID | Return |
SetControlKI
SetControlKI | |
- FLOAT | Value |
- VOID | Return |
SetControlKP
SetControlKP | |
- FLOAT | Value |
- VOID | Return |
SetControlMaxDrivePercentage | |
- FLOAT | Value |
Range 0.0-1.0 | |
- VOID | Return |
SetControlSetpoint
SetControlSetpoint | |
- FLOAT | Value |
- VOID | Return |
SetDriveMode
SetDriveMode | |
- BYTE | Mode |
0=PWM, 1=On/Off/Float | |
- VOID | Return |
SetDynoLoad
SetDynoLoad | |
- FLOAT | Load |
- VOID | Return |
SetFan
SetFan | |
|Sets the speed of the FAN from 0 (MIN) to 3000 (MAX) | |
- UINT | Speed |
- VOID | Return |
SetFrequency
SetFrequency | |
- UINT | Frequency |
Frequency of sine wave in Hz | |
- VOID | Return |
SetLoadCellCalibration | |
- FLOAT | Value |
- VOID | Return |
SetMotorDirection
SetMotorDirection | |
- BOOL | MotorDirection |
0=FW, 1=BW | |
- VOID | Return |
SetMotorType
SetMotorType | |
0=DC, 1=1 Phase, 2=3 Phase | |
- VOID | Return |
SetTCPProps
SetTCPProps | |
Sets the TCP IP address and Port | |
- BYTE | IP0 |
- BYTE | IP1 |
- BYTE | IP2 |
- BYTE | IP3 |
- UINT | Port |
- VOID | Return |
SetThreePhaseDriveMode | |
- BOOL | Mode |
0=Simple, 1=Accurate | |
- VOID | Return |
SetVoltage
SetVoltage | |
Sets the DC Voltage from 0 to 24V | |
- FLOAT | Voltage |
- BYTE | Index |
- VOID | Return |
ZeroLoadCell
ZeroLoadCell | |
- VOID | Return |
