Component: Switch (Toggle, PCB) ()
Author | Matrix Ltd |
Version | 1.1 |
Category |
Switch (Toggle, PCB) component
Miniature toggle switch with metal tang. Pins for PCB mounting.
Please click here to download the component source project: FC_Comp_Source_sw_toggle_pcb.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_sw_toggle_pcb.fcfx
Here is an example Flowcode program to read the value of a switch. Switch
(5V / 11K) * 10K = 4.54545V
