Component: Digital Temperature (EBM004) (EBM Modules)
(Redirected from Component: ID e3fdcca6 1408 4389 8e2d e741b06b3463)
Version | 2.0 |
Category | EBM Modules |
Digital Temperature component
A digital temperature sensor based around the LM75B chip.
Please click here to download the component source project: FC_Comp_Source_EBM004v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM004v1.fcfx
This example simply reads the value from the digital temperature sensor and outputs the value to an LCD as a temperature in degrees C.
Initialise | |
Initialise to default of 11 bit resolution | |
- BYTE | Return |
ReadByte
ReadByte | |
Read a single byte at a specific address from the chip's internal memory. | |
- BYTE | address |
- BYTE | Return |
ReadFloat
ReadFloat | |
Reads the temperature value as a float | |
- FLOAT | Return |
ReadInt
ReadInt | |
Read double byte data from register at address | |
- BYTE | address |
- INT | Return |
Uninit
Uninit | |
Uninitialise and release resources | |
- VOID | Return |
WriteByte
WriteByte | |
- BYTE | address |
- BYTE | data |
- BYTE | Return |
WriteInt
WriteInt | |
- BYTE | address |
- UINT | data |
- BYTE | Return |
