Component: ResistiveTouch (Graphical Library)
Author
Category Graphical Library
ResistiveTouch component
Routines for reading a simple resistive touch screen directly without interface IC.
Please click here to download the component source project: FC_Comp_Source_TouchScreen_Resistive.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TouchScreen_Resistive.fcfx
An example of how to calibrate and read a resistive touch display overlay using the component.
FC6 Icon.png Resistive Touch Demo
Calibration is stored into EEPROM memory so as to avoid having to repeat it on every power up.
Calibrate
Fc9-comp-macro.png Calibrate
Performs a calibration routine which draws a circle at the top left of the screen followed by the bottom right of the screen, from these coordinates the component can work out the corresponding X,Y pixel coordinate.
Fc9-u16-icon.png - UINT Margin
Margin from the edge of the display, Range 0-63
Radius of the calibration touch marker, should be <= margin
GetCalibrationValues
Fc9-comp-macro.png GetCalibrationValues
Returns one of five calibration values used to configure the touchscreen. Populated automatically after running the calibration macro. Allows calibration data to be retrieved and stored into EEPROM by the user.
Fc9-u8-icon.png - BYTE Index
Range: 0-4 Where 0=Xmin, 1=Xmax, 2=Ymin, 3=Ymax, 4=Flags
GetCoord
Fc9-comp-macro.png GetCoord
Gets the coordinate from the last valid touch event
0=X, 1=Y
IsTouched
Fc9-comp-macro.png IsTouched
Check to see if display has been touched
SetCalibrationValues
Fc9-comp-macro.png SetCalibrationValues
Sets the calibration values used to configure the touchscreen. Allows the touchscreen to be re-calibrated from EE memory after a power cycle without re-running the calibration macro.
Fc9-u16-icon.png - UINT Xmin
Calibration value ADC representin Min X
Fc9-u16-icon.png - UINT Xmax
Calibration value ADC representin Max X
Fc9-u16-icon.png - UINT Ymin
Calibration value ADC representin Min Y
Fc9-u16-icon.png - UINT Ymax
Calibration value ADC representin Max Y
Fc9-u16-icon.png - UINT Flags
Flags variable containing margin and X/Y flip status
SetOrientation
Fc9-comp-macro.png SetOrientation
Sets the orientation of the touchscreen to match the orientation of the graphical display.
Range: 0-3 default = 0
Fc9-type-16-icon.png LinkTo
Fc9-type-5-icon.png XP Pin
Fc9-type-5-icon.png XM Pin
Fc9-type-5-icon.png YP Pin
Fc9-type-5-icon.png YM Pin
Fc9-type-6-icon.png XM Analog Pin
Fc9-type-6-icon.png YP Analog Pin
Fc9-conn-icon.png Configuration
Fc9-type-21-icon.png X Pixel
Fc9-type-21-icon.png Y Pixel
Fc9-type-21-icon.png Trigger Pressure
Reading between X and Y which signifies a valid touch pressure.
Fc9-type-21-icon.png Acceptable Noise
Amount of acceptable noise on the input between samples before we allow a valid touch to be recorded.
Fc9-type-16-icon.png Sense Loop Count
Number of times to sample and compare the touch to confirm a valid touch press.
Fc9-type-21-icon.png Average ADC Count
Number of ADC samples used to create an averaged ADC input reading to help reduce input noise.
Fc9-type-21-icon.png Sample Timing (us)
Microsecond delay in between each of the averaged samples.
Fc9-conn-icon.png ADC options
Fc9-conn-icon.png Simulation
Fc9-type-7-icon.png Enable Interrupt
Fc9-type-22-icon.png Interrupt Macro
