Component: API (Arduino Uno) (API Slave Devices)
Version 2.0
Category API Slave Devices
API (Arduino Uno) component
Connects to an Arduino Uno running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_Arduino_Uno_API_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Arduino_Uno_API_Comp.fcfx
The App Developer (Arduino Uno) component allows an Arduino Uno board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the Arduino Uno hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
ZIP Icon.png Arduino Uno App Developer Firmware
The COM port to the Arduino hardware is selected via the App Developer_Ard_Uno componennt COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
  • fixed statistics showing IO / ADC inputs / PWM
  • scrolling log showing all commands and returns
Pin Mapping
App Developer Slave Digital Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
Device Port Pin D0 D1 D2 D3 D4 D5 D6 D7 B0 B1 B2 B3 B4 B5 C0 C1 C2 C3 C4 C5
Arduino Style Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 A0 A1 A2 A3 A4 A5
App Developer Slave Analogue Pin 0 1 2 3 4 5
Device Port Pin C0 C1 C2 C3 C4 C5
Arduino Style Pin A0 A1 A2 A3 A4 A5
App Developer Slave Peripheral Pin I2C SDA I2C SCL SPI MOSI SPI MISO SPI SCK PWM 0 PWM 1 PWM 2 PWM 3 PWM 4 PWM 5 OneWire Servo 0 Servo 1 Servo 2 Servo 3 Servo 4 Servo 5 Servo 6 Servo 7
Device Port Pin C4 C5 B3 B4 B5 D6 D5 B1 B2 B3 D3 D2 D2 D3 D4 D5 D6 D7 D8 D9
Arduino Style Pin A4 A5 11 12 13 6 5 9 10 11 3 2 2 3 4 5 6 7 8 9
Direct Slave Access
Here is a simple demo to switch on and off digital pin 5.
FC6 Icon.png Simple Arduino Uno Demo
Rapid Development - Virtualised SPI
A feature of the App Developer Slave interface is to use the component for rapid development.
The App Developer Slave hardware can be used to take communications from the Flowcode simulation and transfer them to a real world device allowing for easy code generation and test without having to download to a target microcontroller device.
The CS pin and SPI Prescaler are set via the properties of the Injector component.
The SPI Master component is linked to the Injector component via the Injector property.
The Injector component is linked to the App Developer Slave component via the App Developer Slave property.
FC6 Icon.png Arduino Uno App Developer Slave SPI Demo
Rapid Development - Virtualised I2C
The I2C Master component is linked to the Injector component via the Injector property.
FC6 Icon.png Arduino Uno App Developer Slave I2C Demo
Rapid Development - Virtualised UART
The Baud rate and optional RS485 Properties are set via the properties of the Injector component.
The UART component is linked to the Injector component via the Injector property.
FC6 Icon.png Arduino Uno App Developer Slave UART Demo
ADCSample10
Fc9-comp-macro.png ADCSample10
Reads the voltage present on an Analog pin as an 10-bit value range 0-1023
Fc9-u8-icon.png - BYTE ADCChannel
Range: 0-5
ADCSample8
Fc9-comp-macro.png ADCSample8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255
Range: 0-5
ADCSampleArray10
Fc9-comp-macro.png ADCSampleArray10
Range: 0-5
Fc9-u8-icon.png - BYTE SampleCount
Range: 1- 32
Fc9-u16-icon.png - UINT SampleDelay
Fc9-u16-icon.png - UINT Samples
ADCSampleArray8
Fc9-comp-macro.png ADCSampleArray8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
Range: 0-5
Range: 1- 32
Fc9-u8-icon.png - BYTE Samples
8-bit samples returned from the function
ADCSampleAverage10
Fc9-comp-macro.png ADCSampleAverage10
Range: 0-5
Range: 1- 100
Fc9-u8-icon.png - BYTE SampleDelay
ADCSampleAverage8
Fc9-comp-macro.png ADCSampleAverage8
Range: 0-5
Range: 1- 100
ADCSetPrechargeTime
Fc9-comp-macro.png ADCSetPrechargeTime
Specifies the precharge time for the ADC input readings in microseconds. The longer the time the more immune to noise the reading will be.
Fc9-u8-icon.png - BYTE ChargeTime
Default 10
ADCSetReferenceVoltage
Fc9-comp-macro.png ADCSetReferenceVoltage
Specified the reference setting for ADC reads.
Fc9-u8-icon.png - BYTE RefType
0=AREF, 1=VCC, 3=Internal 1.1V
I2CInitialise
Fc9-comp-macro.png I2CInitialise
Fc9-u8-icon.png - BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
I2CReceive
Fc9-comp-macro.png I2CReceive
Fc9-bool-icon.png - BOOL Last
I2CRestart
Fc9-comp-macro.png I2CRestart
I2CSend
Fc9-comp-macro.png I2CSend
I2CStart
Fc9-comp-macro.png I2CStart
I2CStop
Fc9-comp-macro.png I2CStop
I2CTransInit
Fc9-comp-macro.png I2CTransInit
Fc9-u8-icon.png - BYTE DeviceAddress
7-bit Device Address
I2CTransReceive
Fc9-comp-macro.png I2CTransReceive
Data variable to receive into
Fc9-u16-icon.png - UINT Count
Number of bytes to receive
I2CTransSend
Fc9-comp-macro.png I2CTransSend
Data to send
IOGetInputPin
Fc9-comp-macro.png IOGetInputPin
Fc9-u8-icon.png - BYTE Pin
Range: 0-19
IOSetOutputPin
Fc9-comp-macro.png IOSetOutputPin
Range: 0-19
Fc9-bool-icon.png - BOOL State
Range: 0-1
Fc9-comp-macro.png Initialise
OneWireBusReset
Fc9-comp-macro.png OneWireBusReset
Issue a 'ping' on the bus. If there is at least one sensor on the bus then it will generate a presence pulse. Returns 0 if a presense pulse was detected Returns 1 no device was detected
OneWireGetDeviceCount
Fc9-comp-macro.png OneWireGetDeviceCount
OneWireGetIDByte
Fc9-comp-macro.png OneWireGetIDByte
Returns a single byte of the 64-Bit lasered ROM code, 255 on error
Device ID - Range: 0 - NumDevices - 1
Fc9-u8-icon.png - BYTE ByteIndex
Index of the data byte. 0=FamilyCode, 1-6=Serial, 7=CRC
OneWireInitialise
Fc9-comp-macro.png OneWireInitialise
Initialise the OneWire module ready for communications
OneWireMatchROM
Fc9-comp-macro.png OneWireMatchROM
Performs a reset followed by the MatchROM code and then the 8-bit ROM code.
Fc9-u8-icon.png - BYTE FamilyCode
Fc9-u8-icon.png - BYTE SerialNumber
OneWireReceiveByte
Fc9-comp-macro.png OneWireReceiveByte
OneWireScanBus
Fc9-comp-macro.png OneWireScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
OneWireSkipROM
Fc9-comp-macro.png OneWireSkipROM
Performs a bus reset and the sends the SkipROM command byte
OneWireTransmitByte
Fc9-comp-macro.png OneWireTransmitByte
Transmit a byte to the one wire bus a bit at a time
PWMDisable
Fc9-comp-macro.png PWMDisable
Disable a PWM output
Range: 0-5
PWMEnable
Fc9-comp-macro.png PWMEnable
Enable a PWM output
Range: 0-5
PWMSetDuty
Fc9-comp-macro.png PWMSetDuty
Range: 0-5
Fc9-u8-icon.png - BYTE Duty
PWMSetPrescaler
Fc9-comp-macro.png PWMSetPrescaler
Range: 0-5
Fc9-u8-icon.png - BYTE Period
Default 255
RegisterRead
Fc9-comp-macro.png RegisterRead
Read one of the registers on-board the device
Fc9-u16-icon.png - UINT RegisterAddress
The address of the register
RegisterWrite
Fc9-comp-macro.png RegisterWrite
Writes to one of the registers on-board the device
The data value to assign to the register
SPIInitialise
Fc9-comp-macro.png SPIInitialise
SPIPrescaler
Fc9-comp-macro.png SPIPrescaler
Range: 0-2
SPITransfer
Fc9-comp-macro.png SPITransfer
SPITransferTrans
Fc9-comp-macro.png SPITransferTrans
Outgoing data
Fc9-u8-icon.png - BYTE DataIn
Incoming data
ServoDisable
Fc9-comp-macro.png ServoDisable
Disable a Servo output Ch0 to 7 = Pins 2 to 9
Range: 0-7
ServoEnable
Fc9-comp-macro.png ServoEnable
Enable a Servo output Ch0 to 7 = Pins 2 to 9
Range: 0-7
ServoSetPosition8
Fc9-comp-macro.png ServoSetPosition8
Sets the position as an 8-bit value Ch0 to 7 = Pins 2 to 9
Range: 0-7
Fc9-u8-icon.png - BYTE Position
Range: 0-255
Fc9-conn-icon.png Connection
Fc9-type-16-icon.png COM Port
Lists all the current available COM port hardware on your PC.
Fc9-type-7-icon.png Refresh Ports
Fc9-conn-icon.png API Peripherals
Fc9-type-21-icon.png Digital IO
Fc9-type-21-icon.png Analog Input
Fc9-type-21-icon.png Analog Output
Fc9-type-21-icon.png PWM Output
Fc9-type-21-icon.png I2C Bus
Fc9-type-21-icon.png SPI Bus
Fc9-type-21-icon.png UART
Fc9-type-21-icon.png OneWire
Fc9-type-21-icon.png SERVO
Fc9-conn-icon.png Console
Fc9-type-7-icon.png Console Log
Create an automatic console log of the commands sent to the Arduino
Fc9-type-16-icon.png Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns
