Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Main /
Using Worksheets<^Course Index^>(:nl:) Throughout this course there are worksheets which can be printed out or can be worked on directly from your screen. To print out a copy of a worksheet click on the "print" label just below the search box. This will format the worksheet into a print friendly page. You can then select the PRINT option from your browser's menu or toolbar. (You may need to consult your browser's help file.) Your working and answers to all worksheets should always be presented on a new sheet of paper or in your log book. If graph paper is needed you can find it here and print it out. A calculator is available on most computers in your Accessories program group.(For further instructions please refer to your Windows help file). For most worksheets you will need some apparatus - either a copy of TINA circuit simulator or physical components to use.(:nl:)(:table style="clear:both":)
Page last modified on August 18, 2011, at 08:30 AM
