(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:)
(:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :)
* Print
(:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:)
* %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]]
(:ifend:) :)
* Login
<^< Light Dependent Resistors | Course Index | Capacitor Specifications >^>(:nl:)
A capacitor is a device for storing electric charge. In effect, it is a reservoir into which charge can be deposited and then later extracted. Typical applications include reservoir and smoothing capacitors for use in power supplies, coupling a.c. signals between the stages of amplifiers, and decoupling supply rails (i.e., effectively grounding the supply rails as far as a.c. signals are concerned).
(:nl:)(:table style="clear:both":)
<^< Light Dependent Resistors | Course index | Capacitor Specifications >^>
