Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals Passive Components * Introduction: Passive Components * Resistors * Capacitors ## Capacitor Specifications ## Preferred Values: Capacitors ## Capacitor Markings ## Examples: Capacitor Markings ## Capacitor Symbols ## Capacitor Construction ## Capacitors in Series ## Capacitors in Parallel ## Examples: Capacitors in Circuits ## Variable Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Capacitors in Series<^< Capacitor Construction | Course Index | Capacitors in Parallel >^>(:nl:) ![]() When two capacitors are connected in series, the same charge is present on each of them and the effective capacitance of the circuit will always be less than any one of the two capacitors taken alone. The effective capacitance, C, of a circuit with two capacitors, C'_1_' and C'_2_', connected in series is given by: 1 / C = 1 / C'_1_' + 1 / C'_2_' Similarly, where three capacitors (C'_1_', C'_2_', and C'_3_') are connected in series, the effective capacitance of the combined circuit will be given by: 1 / C = 1 / C'_1_' + 1 / C'_2_' + 1 / C'_3_' In the case of two capacitors, the formula can be more conveniently re-arranged as follows: C = (C'_1_' x C'_2_') / (C'_1_' + C'_2_') This can be remembered as "product over sum". (:nl:)(:table style="clear:both":)
Page last modified on July 21, 2011, at 02:52 PM
