Thanks - have had a happy afternoon watching this one. Not sure where the other has been - but they are very hard to spot unless they move...
Almost makes up for this morning - water board turned up looking for a leak - reckon 60L per min have been coming out somewhere - so now have a long blue pipe from the 'main' to an outside tap...
ESP32 - Reusing example source - Esp32-Camera
- Has thanked: 107 times
- Been thanked: 538 times
Re: ESP32 - Reusing example source - Esp32-Camera
I was keen to have a go with this so I bought the chip pack but it fails to compile. I have no idea what the error is being an esp noob
Any pointers Martin?
- examples(1).msg.txt
- (7.38 KiB) Downloaded 77 times
- Has thanked: 517 times
- Been thanked: 135 times
Hi Martin!
First thank´s for your sharing, very interesting I am at the moment waiting in the airport and of course looking in FC forum, then I discover your test with the camera, read a little bit, before take off, and emediately order a couble these module. Honest, I have absolute no experience with this, so maybe stupid question. In the first examble I suppose the camera is take a photo every second, I guess you not are using SD card, how do you get the picture to your PC? In the next examble you use a SD card, so this I understand. Is it possible to send the picture via wifi to the PC or via BT, could be nice to sit in the living room an see what happen in the garden Not study all your exable yet, I will do.
Thank´s in advance.
Jorgen
Thank´s in advance.
Jorgen
- Has thanked: 75 times
- Been thanked: 220 times
Try renaming examples(1).fcfx to examples1.fcfxI was keen to have a go with this so I bought the chip pack but it fails to compile. I have no idea what the error is being an esp noob
- Has thanked: 297 times
- Been thanked: 429 times
I'd forgotten about this post as I was travelling around that time.
Last night I downloaded the second post of "examples" from above, which being named the same as the first post, became examples(1), which I didn't notice at the time. As Leigh mentions, this won't compile with parenthesis so I saved as something else. Unfortunately whilst compiling to Hex it failed well into the process.
However as I'd forgotten about the post I'd forgotten the first post in which Martin informs he's getting espressif code to run within FC and you have to download the camera source from github.
Well worth reading from first post.
Thanks and very true. Long winded to get it to work.
I loaded a program via arduino ide to test it. Point of note - dont try to program via arduino with sd card inserted, doesnt seem to like it
