accelerometer wit motion
- Been thanked: 4 times
Hello everyone, I have acquired a very interesting accelerometer module with a compass, is there anyone who has the component created? the model is wit motion, it has i2c and uart, I attach document:
- Has thanked: 157 times
- Been thanked: 185 times
Re: accelerometer wit motion
Hi Asmatec
I use a supported IMU the MPU6886.(6 Axis)
mayby it's not what you are looking for but if you tell me what you like to do, I can have a look if it's woorking with this modul
https://shop.m5stack.com/products/6-axi ... nitmpu6886
and is there a big distributor where your WT61P sensor sells?
- Snag_b29335.png (132.43 KiB) Viewed 2112 times
Hello Stefan,
I found the sensor on this page, it has its own communication software, what I really need is something that indicates the inclination and the north, I am developing a solar tracker through the geographic coordinates of the sun.
https://es.aliexpress.com/item/10050030 ... pt=glo2esp
Miguel.
Miguel.
I have done some tests with hmc5883l but in the compass reading it only appears 270 no matter what position I put the sensor in
- prueba EXPA_IO gps solar v.3.fcfx
- (14.79 KiB) Downloaded 106 times
Hi Asmatec
Check
-if you have pullup resistor for the 2Pin.
-clock and data not reversed
-3.3Volt or 5Volt problem
try if you change channel2 to software
I will get one hmc5883l and try next week
Check
Hi Stefan,
The communications are fine, the x and z axes are working but the measure of the compass in degrees sometimes changes the value but it does not correspond to what it should read!
Hi asmatec
At the moment I am trying to clarify all possibilities which magnetometers are available and/or which 9 axis sensors are available. For my project I need to use one.
I can use a 6axis sensor and with additional magnetometer
or a 9axis sensor
From Flowcode there are already components
HMC5883L magnetometer
QMC5883L magnetometer
LSM9DS1 9axis
and for these sensors I have already asked Ben to make a component
BMM150 magnetometer
ICM 20948 9axis
or a 9axis sensor
LSM9DS1 9axis
BMM150 magnetometer
ICM 20948 9axis
Hi Stefan,
As I mentioned before, the problem is that the component of the HMC5883L magnetometer doesn't work well, could you verify it?
