HI kersing / Flowcode
Thanks for that answer
But I can't get to upload code to ESP32 DEVKITV1. Nothing is happening...
User Windows v11
Look here! Compiler Messages:
In the Arduino IDE I can use COM4, so COM4 and Arduino work together with ESP32 DEVKITV1 !
That's why it seems strange that it doesn't work with Flowcode v10. Same Coder and same port4
Best regards
Monie
Flowcosev10
- Has thanked: 1 time
- Has thanked: 66 times
- Been thanked: 58 times
Re: Flowcosev10
Means the code is being uploaded to your device.Chip is ESP32-D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None Crystal is 40MHz
MAC: 0c:b8:15:c2:35:7c
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Compressed 3072 bytes to 103...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (103 compressed) at 0x00008000 in 0.0 seconds (effective 1370.6 kbit/s)... Hash of data verified.
Compressed 24768 bytes to 15467...
Writing at 0x00001000... (100 %)
So that is why I am asking it you are using the right pins for the device for your flashing led test.
Re: Flowcosev10
HI kersing
Unit: ESP32 DEUKITU1
See the device connection below in the picture:
Hope you can see how the ESP-IDF unit is connected
Best regards
Monie
Best regards
Monie
Re: Flowcosev10
HI mnfisher
I have tried to using the esp32 wroom-32 settings, but without success....?
Monie
Monie
- Has thanked: 104 times
- Been thanked: 515 times
Re: Flowcosev10
Which bit didn't work? Did it upload and nothing happen or upload fault?
Can you 'connect' to the esp using putty or the serial in Arduino ide and see if it outputs anything?
Re: Flowcosev10
Hello everyone
Tried many times to upload and nothing happened or did it upload error?
Monie
Monie
