how i can print my diagram flow in flc9 ??
thanks solozerouno
print a flowcode diagram ??
- Has thanked: 2 times
- Been thanked: 2 times
- Has thanked: 513 times
- Been thanked: 473 times
Re: print a flowcode diagram ??
Hi, solozerouno.
Select the Flowchart you want to print.
Go to File, select Export.
Select Save the macro as an image.
The image is then saved for yo to print it.
- Has thanked: 150 times
- Been thanked: 171 times
Hi solozerouno, Hi Martin
There is a very nice tool in Flowcode to generate a HTML Code from your project.
Make information about your project.
Try once and open the generated HTML file.
HTML File you can open with the InternetExplorer
or if you open it with word you can edit it and you can save it as pdf.
one more advantage: In the generated folder are all picture from the macros
