Welcome everyone.
I need your help.
We bought a new version license to work with STM microcontrollers because the older versions did not have STM support but we solved the problem.
When we try to make a break according to a specific pin (see the button and give the information, then go back and continue working from where the button went).
INTERRUPT works only on timers,
The Help and resources column says in the INT section, "Triggered when an external stimulus is used on an external interrupt (INT) pin (eg a Button press).
Is it really that hard to help in this situation?
No one you know on this forum?
I really need your help, please if anyone can respond to me
FlowCode STM
- Has thanked: 3 times
- Has thanked: 512 times
- Been thanked: 472 times
Re: FlowCode STM
Hi, sulkhan.
When replying, select the Attachments tab.
Select Add files then a new window will open.
Browse to the folder you have your flowchart saved in, select the file that's is
then select Open.
Your flowchart should then be attached to your post.
Your Flowchart Name.fcfx
