Hello FC Team,
I`m missing the RXINT Interrupt function inside the ESP32 command interrupt icon.
I´ll compare this with the PIC-8 command interrupt icon. There you have a choice to select this important function.
Is a RXINT possible with the ESP32??
BR
Dirk
ESP32 UART RXINT interrupt is missing
- Has thanked: 6 times
- Been thanked: 12 times
- Has thanked: 157 times
- Been thanked: 185 times
Re: ESP32 UART RXINT interrupt is missing
Hi Dvcam99
Interrupt is working on my esp32. I used A3 for rx pin
and
GPIO3 for the Interrupt
and
Hi Stefan,
many thanks for the feedback.
Yes I saw this possibility too but you can trigger only at the rising or falling edge of the input.
I`m looking for example for incoming received byte trigger. Same like we have in the PIC8 section.
BR
Dirk
BR
Dirk
Happy FC9, FC-8 and FC-6 professional user
- Has thanked: 75 times
- Been thanked: 220 times
UART Rx interrupt is now done, it will be available from the auto update system sometime soon
Note that UART receive is buffered, so interrupt is not as necessary on ESP32 as other (non-RTOS) devices
Hello Leigh,
very good news!!
I`ll check it out asap it is available.
Regarding the ESP32 buffer, do you know how many bytes it can store??
BR
Dirk
very good news!!
BR
Dirk
