Hi everyone
the medianfloat component does not return decimal values but only integers or maybe I didn't fully understand how this should work, I attach a simple test code
happy holidays to everyone
thank's
- Been thanked: 5 times
- Has thanked: 170 times
- Been thanked: 287 times
Re: medianfloat component
There could be a problem with the component. It does return float values, but only the values entered. It does not return the average of the 2 consecutive median values when there are an even number of samples. Instead, it returns one of those sample values. We will get this fixed.
Your example adds only whole numbers to the list which is why you are only seeing whole numbers being returned.
Ok Steve thank you, something is wrong, the calculations did not return to me, I would also take a look at the other median components, I’m using the 32 bit and it does not seem right.
I have only tried simulating this component. Does simulation work for you?
