Hi!
Just received my ESP 32 and want to test. After install the toolchain I try to compile to chip, I get the message "ESP toolchain not installed is there some special I have to do?
Br jorgen
ESP tool chain not installed!
- Has thanked: 517 times
- Been thanked: 135 times
- Has thanked: 75 times
- Been thanked: 220 times
Re: ESP tool chain not installed!
Did you follow all the instructions in the link below, carefully
... including the Flowcode Global setting?
https://flowcode.co.uk/wiki/index.php?t ... Toolchains
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Tryed again, and yes, I have forgot the location in global setting, sorry. Now it begin to compile, but will not program the ESP32
- CompEsp.PNG (27.07 KiB) Viewed 4760 times
You also need to set the COM programming port, see this post ..
viewtopic.php?p=57#p57
Some ESP modules also need the BOOT switch pressed when programming.
Hi LEigh!
Your suggest already tryed. I cannot see any comport in the settings , no matter what I do. I hear the pling when I connect the USB and see Com17 when I att the USB in devicemanager
- Port.PNG (24.54 KiB) Viewed 4736 times
