Timer problems PIC18LF14K50
Has thanked: 284 times
Been thanked: 412 times
Re: Timer problems PIC18LF14K50
Post by chipfryer27 »
As mentioned I don't have the chip but I do have other PICs that offer the same functionality.
Using a PIC16F1939 in an BL0080 multiprogrammer (coz it was already in it) using an 8MHz clock, I set up a very basic chart with an LCD didplay and an interrupt on Timer 0 set to CLK0 with a prescale of 1:128 giving an interrupt of apprpox 60Hz.
The ISR would simply increment a counter (roughly 60 times per second). In Main loop if the counter reached 120 it would display a message before repeating.
No issues, did exactly as expected.
I then changed the chart to interrupt on TOCKI (rising edge) with prescaler set at 1:1 and with a Signal Generator set to a 4Vpp Square Wave with 50% duty connected to pin RA4 and set to 8MHz I got my interrupts as expected.
So whilst this doesn't exactly help you, it does confirm that the FC Timer 0 interrupt on TOCKI feaure does work.
It may mean an issue with that particular chip, or possibly connections / settings. Do you have a signal generator to test with?
electronick
Has thanked: 5 times
Post by electronick »
Hi.
I have also used the T0CKI feature on other chips Both using C code and FC interrupt with success.
This chip doesn´t seem to be as easy as the other though and perhaps it has something to do with its limited program memory and RAM?
Because as soon as I add USB serial component to the chart all timers but Timer2 stops functioning, and >40% program memory, >55% Ram disappears.
I will give it a few more tries then use some other chip that I have previously used instead.
About the hardware, I have tested it by tying INT0(RC0), connected to RC5, and a 12Vp-p, 60kHz signal which produces a 3,3-0,05VDC square wave signal on RC0-RC5.
Signals were confirmed by oscilloscope.
Nick
