ST7789 display
- Has thanked: 37 times
- Been thanked: 29 times
Re: ST7789 display
The compiler output message file is in the same folder as the hex file and is 'yourfilename'.msg.txt
Re: ST7789 display
One of those Fridays again.
The previous versions of my ESP32 Flowcode programs no longer compile.
I did an upgrade to the latest version of FC9 some time ago, that worked on some PIC applications without issues, but no longer on the ESP32 programs.
I got the same problem as I had earlier, which I fixed by completely reinstalling the ESP32 toolchain.
Did that again, no joy.
Question: in the user guide to install the toolchain, version 4.0 of the ESP-IDF is shown in the selection screen.
But currently there are later version from which you can choose, 4.1, 4.2, up to 5.0.
Should I re-install with V4.0?
Jan
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
idf.py build
Please use idf.py only in an ESP-IDF shell environment.
Build Failed
Autoclose turned off
Re: ST7789 display
Please look this output:
At the top: Setting IDF_PATH: C:\Users\jandi\esp-idf - which is correct, that's where I installed stuff.
But then later, it complains it can find stuff in C:\esp-idf-tools\tools\cmake\3.13.4\bin
Why does it look there?? The location is correctly set to C:\Users\jandi\....
I will uninstall all and re-install to C:\esp_idf etc. See if that works.
Jan
C:\Users\jandi\OneDrive - Linear Audio\2a - AR xt>REM DIR: FCD\ESP\Batch\esp32_build.bat
Building ESP32 wroom log scale test ...
Adding ESP-IDF tools to PATH...
C:\Users\jandi\esp-idf-tools\tools\xtensa-esp32-elf\esp-2020r3-8.4.0\xtensa-esp32-elf\bin
C:\Users\jandi\esp-idf-tools\tools\xtensa-esp32s2-elf\esp-2020r3-8.4.0\xtensa-esp32s2-elf\bin
C:\Users\jandi\esp-idf-tools\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin
C:\Users\jandi\esp-idf-tools\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin
C:\Users\jandi\esp-idf-tools\tools\cmake\3.16.4\bin
C:\Users\jandi\esp-idf-tools\tools\openocd-esp32\v0.11.0-esp32-20211220\openocd-esp32\bin
C:\Users\jandi\esp-idf-tools\tools\ninja\1.10.0\
C:\Users\jandi\esp-idf-tools\tools\idf-exe\1.0.1\
C:\Users\jandi\esp-idf-tools\tools\ccache\3.7\
C:\Users\jandi\esp-idf-tools\tools\dfu-util\0.9\dfu-util-0.9-win64
C:\Users\jandi\esp-idf-tools\python_env\idf4.2_py3.7_env\Scripts
C:\Users\jandi\esp-idf\tools
Python requirements from C:\Users\jandi\esp-idf\requirements.txt are satisfied.
idf.py build
[0/1] Re-running CMake...
FAILED: build.ninja
C:\esp-idf-tools\tools\cmake\3.13.4\bin\cmake.exe -SC:\Users\jandi\OneDrive_-_Linear_Audio\2a_-_AR_xt\ESP32_wroom_log_scale_test -BC:\Users\jandi\OneDrive_-_Linear_Audio\2a_-_AR_xt\ESP32_wroom_log_scale_test\build
CreateProcess failed: The system cannot find the file specified.
ninja: error: rebuilding 'build.ninja': subcommand failed
Running ninja in directory c:\users\jandi\onedrive_-_linear_audio\2a_-_ar_xt\esp32_wroom_log_scale_test\build
Executing "ninja all"...
ninja failed with exit code 1
Build Failed
Jan
Re: ST7789 display
Its a mess. Uninstalled and deleted everything related.
Re-installed from scratch to C:\esp-idf and C:\esp-idf-tools
Now I get this:
As to: See also "C:/Users/jandi/OneDrive_-_Linear_Audio/2a_-_AR_xt/ESP32_wroom_log_scale_test-2/build/CMakeFiles/CMakeOutput.log". - there is no such directory or file.
I give up. It's Saturday.
Jan
Now I get this:
C:/esp-idf/tools/cmake/project.cmake:371 (idf_build_process)
CMakeLists.txt:13 (project)
-- Configuring incomplete, errors occurred!
Running cmake in directory c:\users\jandi\onedrive_-_linear_audio\2a_-_ar_xt\esp32_wroom_log_scale_test-2\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32 -DCCACHE_ENABLE=1 c:\users\jandi\onedrive_-_linear_audio\2a_-_ar_xt\esp32_wroom_log_scale_test-2"...
cmake failed with exit code 1
Jan
Re: ST7789 display
Did a clean install on another computer where that toolchain was never installed before. Same problem.
The installation guide says to install version 4.0, but at this time the only selections available are 4.2 and up to 5.0.
Could it be that the install script assumes 4.0 is used and gets mixed up when you install another version, which is different/incompatible?
Jan
Jan
- Has thanked: 138 times
- Been thanked: 730 times
Re: ST7789 display
If v4.1 is installed and working - then probably none....
If you want to use newer variants of the esp32 (S2 or C3 for example) - then you might need to change.
I'd messed up my install (I will try things - that don't always (ever?) go to plan) - so reinstalled using the latest version (having seen Ben's posts). It seems to need a few changes to my code
