Max7219_v.fcpx and Max7219_v9.fcpx Martin Fisher
Has thanked: 885 times
Been thanked: 214 times
Flowcode v11 Re: Max7219_v.fcpx and Max7219_v9.fcpx Martin Fisher
Post by jgu1 »
Hi Martin!
Tank you for your help.
I know that the Max7219_v2.fcpx works in FC8, at least for scrolling on both dieretion 0 and 1 displays.
I understood from you that it might be something to do with a few commas that need to be removed from the macro, after which it should work in Flowcode 11.
Wouldn’t it perhaps be easier to simply remove those commas from the Max7219_v2.fcpx file, rather than you having to spend a huge amount of time creating or modifying the whole component?
Just a thought. :)
Best regards,
Jørgen
Max7219_v2.fcpx
(8.31 KiB) Downloaded 8 times
Has thanked: 176 times
Been thanked: 1011 times
Post by mnfisher »
Yes - and there is just one small flaw with the plan....
v2 might be lost in the mists of time :-(
Post by jgu1 »
Well, is it not possible to edit in the one I att. ?
Post by mnfisher »
No - I don't know if it's possible to 'decompile' the fcpx file. I did have an attempt one time (add a function, look at the hex and repeat - but I didn't gain enlightenment)
Post by jgu1 »
Ok Martin, Don´t do more, at least the v9 work fine in FC11, I avoid to Scroll 0 :D
Thank´s
Has thanked: 763 times
Been thanked: 828 times
mnfisher wrote:
Sat Sep 05, 2026 10:47 am
Hi Martin,
With the component loaded, right - click on the function within Project Explorer and select Show as Flowchart, or Blocks etc.
Post by mnfisher »
Hi Martin, thanks - yes that works for 'downloadable' macros.
I'll have an experiment with v2 ...
Post by mnfisher »
With scrolling in direction '0' (hopefully...)
Max7219_v9.fcpx
(9.06 KiB) Downloaded 6 times
