UART "SendString" command problem [SOLVED]
Sasi
Has thanked: 43 times
Been thanked: 15 times
Re: UART "SendString" command problem
Post by Sasi »
Sorry, I phrased the question poorly.
So far I have compiled my Flowcode10 projects with the default compiler (XC8 v2.10).
I would like to know if if I recompile these projects with the XC8 v2.50 compiler, can I expect any operational differences or errors in the target circuit due to the version difference?
But the answer to this question is probably NO, since they are generally backward compatible and you are also using this version. :)
Sasi
ps.:
That was a too fast conclusion. :roll:
viewtopic.php?t=3102
Sasi
Post by Sasi »
I'm moving to the v2.50 compiler with Basic Optimization.
The optimization modification is described here:
viewtopic.php?p=19683#p19683
PS:Unfortunately, this hasn't given me a solution. :(
Sasi
Post by Sasi »
The solution was to set the "Table Read Protect Boot" bit to "Disabled" in the configuration settings.
More information can be found here:
https://developerhelp.microchip.com/xwi ... tion-bits/
Sasi
