RS232 Wireless help!
Has thanked: 358 times
Been thanked: 567 times
Re: RS232 Wireless help!
Post by chipfryer27 »
Hi Jorgen
Sorry to brief I will try and respond more later.
You loop checking for incoming data on the Rx, but this approach is prone to missing activity if the data arrives whilst you are busy elsewhere.
My suggestion would be to include a Circular Buffer and an interrupt set for RxInt to capture any incoming transmission and in the ISR simply put the incoming values in the Circular Buffer
ISR would contain (for example):-
This way you will never miss any incoming data and in your Main loop you can search for your keyword within the buffer.
Not sure using Compare$ is the best option. Depending on your transmission medium there may be "control characters" such as CR / LF being sent and if so they may be captured in your string. If they are then your string won't just contain "Open". This may or may not be a concern though.
daddytims_tims
Has thanked: 118 times
Been thanked: 13 times
Flowcode v10 Re: RS232 Wireless help!
Post by daddytims_tims »
Hi Jorgen
Here's an Example, that's works. Related to what chipfryer is saying above.
I recently created it with an Esp32.
Ryan
Esp32_hc05.fcfx
(15.12 KiB) Downloaded 404 times
jgu1
Has thanked: 688 times
Been thanked: 177 times
Post by jgu1 »
Hi Ryan and Chipfreyer!
Thank you for your help and examble. I certenly will perform a test.
I have just made a test with my own program, and yes, working first time :D connected directly tx out to rx in. Next step via HC12 wireless.
I have add the programs, if anybody can use them, hereby :lol:
I have no expeience with Cirkular buffer, maybe a good idea to play with this. ;)
Again thank´s to all.
Jorgen
RX_PortOscon.fcfx
(12.13 KiB) Downloaded 545 times
Tx_PortOscon.fcfx
(12.49 KiB) Downloaded 509 times
