API FCD.GetItemValue
<sidebar>API contents</sidebar> Gets a paths item value from the FCD document
Class hierarchy
- FCD
- GetItemValue
STRING PathName
- The '.' separated path through the FCD to look in
STRING ItemName
- The name of the item to read
STRING DefText
- A default value to return if the item is not found
- The default value for this parameter is: ""
Returns the paths item value from the FCD document
- Add to a calculation icon:
result = ::FCD.GetItemValue("pathname", "itemname", "deftext")
