API Panel.Position.RotateZ
Error creating thumbnail: Unable to save thumbnail to destination
RotateZ |
| Rotates the object around the Z axis | |
Error creating thumbnail: Unable to save thumbnail to destination - HANDLE
Handle |
| The position or component to update | |
PivotHandle |
| An optional position to treat as the origin to rotate around | |
Error creating thumbnail: Unable to save thumbnail to destination - FLOAT
Degrees |
| Number of degrees to rotate by | |
Error creating thumbnail: Unable to save thumbnail to destination - NONE
Return |
The rotation call allows an object to be rotated around any point in the target objects local Z axis. This has the effect of altering the roll of the object - in terms of an aeroplane this makes the plane spin around.
The handle must be a valid handle to a component or position, or a quoted (string) name of an object that can be selected on the panel.
The image to the right shows a cube with it's axis positions identified.
Calling the simulation api Panel.Position.RotateZ(MyCube,MyCube,1) will rotate the object in one-degree steps along it's Z-axis as shown by the blue rotation arc. To rotate the cube in a counter direction simply specify a negative number for the degrees parameter.
The screenshot from Flowcode v6 below shows a cuboid with it's internal axis shown (blue is the Z-axis line), and also a circle that cuts right through the cuboid's Z-axis (see example section below for links to the file) When the program runs the cuboid rotates along it's Z axis.
See also
- Add to a calculation icon:
::Panel.Position.RotateZ(handle, pivothandle, degrees)
Flowcode example file
Download
SIMAPI_Panel_Position_RotateZ_v1 and open it in Flowcode v6.
The sample file
SIMAPI Panel Position RotateXYZ rotates a grouped object around its X, Y, and Z axis.
