Component: DC Motor (Mechatronics)
Version | 1.2 |
Category | Mechatronics |
DC Motor component
DC Motor that can be driven in one or both directions using digital output pins, PWM or HBRIDGE peripherals.
Please click here for the component source code: FC_Comp_Source_DCMotor_2d.fcfx
DALI Slave Example, listens for DALI messages and checks that the group is correct before attempting to process the request and if required reply to the master.
DALI Slave Example1
For a DALI Master example see: Component: DALI Master (Comms: System)
Coast |
Turn off power to the motor by setting the pins according to the 'Coast Pattern' property. | |
Return |
Break |
Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property. | |
Return |
Disable |
Disable the motor output | |
Return |
Forwards |
Set the motor turning in the forwards direction by setting the pins according to the 'Forwards Pattern' property. | |
Duty |
Sets the motor power for PWM or H-Bridge outputs | |
Return |
Enable |
Enables the motor output | |
Return |
Reverse |
Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property. | |
Duty |
Return |
GetSimAngle |
Gets the angle of the simulated motor shaft in degrees. | |
Return |
