Component: DC Motor (Mechatronics)
Version | 1.2 |
Category | Mechatronics |
DC Motor component
DC Motor that can be driven in one or both directions using digital output pins, PWM or HBRIDGE peripherals.
Please click here to download the component source project: FC_Comp_Source_DCMotor_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DCMotor_2d.fcfx
Break
Break | |
Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property. | |
- VOID | Return |
Coast
Coast | |
Turn off power to the motor by setting the pins according to the 'Coast Pattern' property. | |
- VOID | Return |
Disable
Disable | |
Disable the motor output | |
- VOID | Return |
Enable
Enable | |
Enables the motor output | |
- VOID | Return |
Forwards
Forwards | |
Set the motor turning in the forwards direction by setting the pins according to the 'Forwards Pattern' property. | |
- UINT | Duty |
Sets the motor power for PWM or H-Bridge outputs | |
- VOID | Return |
GetSimAngle
GetSimAngle | |
Gets the angle of the simulated motor shaft in degrees. | |
- FLOAT | Return |
Reverse
Reverse | |
Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property. | |
- UINT | Duty |
- VOID | Return |
