API FCD.GetItemValue
Revision as of 14:07, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "class="wikitable" style="width:60%; background-color:#FFFFFF;"" to "class="mtx-class-macrotable wikitable"")
GetItemValue
Gets a paths item value from the FCD document
- STRING PathName
The '.' separated path through the FCD to look in
- STRING ItemName
The name of the item to read
- STRING DefText
A default value to return if the item is not found
- STRING Return
FCD files are XML files. The PathName must be a list of items, not including the XML root tag of the tags where the XML attribute ItemName is to be located. So to extract the FLASH memory size Pathname="device.memory" and ItemName="bytes".
If the ItemName is not found in the specified location then DefText will be returned instead.
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::FCD.GetItemValue("pathname", "itemname", "deftext")
