Component: I2C Free (Peripheral CAL)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.3 |
| Category | Peripheral CAL |
I2C Free component
Chip Abstraction Layer for Two Wire I2C Communications
Please click here to download the component source project: FC_Comp_Source_I2C_Free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2C_Free.fcfx
| Slave_Uninit | |
| Uninitialise the Slave | |
| GetValue | |
| Get the Named property value. | |
| Name | |
| Master_Stop | |
| Output a Master Stop | |
| Master_Uninit | |
| Uninitialise the Master | |
| GetConsoleHandle | |
| Obtains the CAL console handle | |
| Slave_TxByte | |
| Send a data byte, returns Ack/Nak from Master 0=Ack=More, 1=Nak=Last | |
| Data | |
| Slave_RxByte | |
| Returns the data received, and sends either Ack or Nak Set parameter Last as: 1=Last=Nak, 0=Ack=More | |
| Last | |
| Sends Ack if 0, else Nak | |
| SetValue | |
| Change Named property to new Value. If "CHANNEL" the ports will be also updated from the fcd | |
| Name | |
| Value | |
| port value as string | |
| Master_Init | |
| Initialise the Master | |
| Master_Start | |
| Output a Master Start sequence | |
| Master_TxByte | |
| Send a data byte | |
| Data | |
| Master_Restart | |
| Output a Master Restart sequence | |
| GetList | |
| returns Named property List as filter string | |
| Name | |
