Component: Servo Controller Mod (Mechatronics)
Revision as of 11:52, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.5
Category Mechatronics
Servo Controller Mod component
Can control up to eight standard PWM driven servo's. 'Servo Object' properties allow you to connect the controller to on-screen simulations using the "Servo Motor" component and its derivatives.
Please click here to download the component source project: FC_Comp_Source_Servo_Controller_Mod.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Servo_Controller_Mod.fcfx
Importing from v5
The servo component in Flowcode v6 onwards has a new Initialise macro which will need to be added to your program before any other calls to the servo motor component are made.
Controlling a servo with an analogue input
This example reads the value of the analogue potentiometer and uses this to set the position of the servo motor. FC6 Icon.png Servo Example 1 The Servo controller is linked to the standard servo component but this could be linked to any object on the panel.
Creating a multi-axis actuator using servo motors
This example links two servo motors together using panel primitive objects and groups. FC6 Icon.png Servo Example 2 The Servo controller can handle up to 8 motors and is used to control both of the standard servo components on the panel.
DisableServo
Fc9-comp-macro.png DisableServo
Disables a servo channel effectivly disabling the motor.
The channel to set the position for. First channel is zero.
SetPosition
Fc9-comp-macro.png SetPosition
Moves directly to the specified position with no interpolation.
Fc9-u8-icon.png - BYTE Position
Target position to move towards.
MoveToPosition
Fc9-comp-macro.png MoveToPosition
Moves a single step towards the new position, the rate of movement is determined by how often the move to macro is called. Returns 1 if the position has been reached.
SetTrim
Fc9-comp-macro.png SetTrim
Allows the level of trim for each servo channel to be adjusted progmatically.
Fc9-u8-icon.png - BYTE Trim
0=0us, 1=+25us, 2=+50us, 3=+75us, 4=+100us, 5=-25us, 6=-50us, 7=-75us, 8=-100us
IsAutoMoving
Fc9-comp-macro.png IsAutoMoving
Is the AutoMoveToPosition movement complete. Returns 1 if the servo is still moving. Returns 0 if the servo movement is complete.
AutoMoveToPosition
Fc9-comp-macro.png AutoMoveToPosition
Automatically moves towards the new position with a fixed rate of 100 steps per second.
Position to move to.
EnableServo
Fc9-comp-macro.png EnableServo
Enables a servo channel effectivly setting the position of the motor to the value in the local position variable.
SetAutoMoveSpeed
Fc9-comp-macro.png SetAutoMoveSpeed
Sets the speed of the auto move to position macro. Default speed is 1.
Fc9-u8-icon.png - BYTE Speed
1=Slowest (Default), 2= Double, 3=Triple, 4=Quadruple
Fc9-comp-macro.png Initialise
Sets up the servo motor interrupts
Fc9-type-16-icon.png Channels (1 - 8)
Set the number of servo's that you need to control. Value from 1 to 8.
Fc9-type-5-icon.png Channel 0
Pin on which to output PWM for the servo motor.
Fc9-conn-icon.png Trim
Fc9-type-16-icon.png Trim 0
Trim the pulse width for this channel. Use this to trim the positioning of two servos so that similar input values will produce the same degree of movement.
Fc9-conn-icon.png Pulse Width
Fc9-type-21-icon.png Minimum (us)
Shortest pulse width that will be used.
Fc9-type-21-icon.png Maximum (us)
Longest pulse width used for the PWM signals.
Fc9-conn-icon.png Simulation
Fc9-type-17-icon.png Servo Object 0
Drag a servo motor component onto the System Panel, and then select it here, to create an on screen simulation of the way that your flowchart moves the servo's. Servo motors should be based on the 'Servo Motor Base' component, or use a custom component set to responf to 'User.Notify' events (ID = n/a, Data = Position (0-127)).
