Component: Servo Controller Mod (Mechatronics)
Author | Matrix Ltd |
Version | 1.5 |
Category | Mechatronics |
Servo Controller Mod component
Can control up to eight standard PWM driven servo's. 'Servo Object' properties allow you to connect the controller to on-screen simulations using the "Servo Motor" component and its derivatives.
Please click here to download the component source project: FC_Comp_Source_Servo_Controller_Mod.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Servo_Controller_Mod.fcfx
Importing from v5
The servo component in Flowcode v6 onwards has a new Initialise macro which will need to be added to your program before any other calls to the servo motor component are made.
Controlling a servo with an analogue input
This example reads the value of the analogue potentiometer and uses this to set the position of the servo motor. Servo Example 1 The Servo controller is linked to the standard servo component but this could be linked to any object on the panel.
Creating a multi-axis actuator using servo motors
This example links two servo motors together using panel primitive objects and groups. Servo Example 2 The Servo controller can handle up to 8 motors and is used to control both of the standard servo components on the panel.
AutoMoveToPosition
DisableServo
DisableServo | |
Disables a servo channel effectivly disabling the motor. | |
- BYTE | Channel |
The channel to set the position for. First channel is zero. | |
- VOID | Return |
EnableServo
Initialise | |
Sets up the servo motor interrupts | |
- VOID | Return |
IsAutoMoving
IsAutoMoving | |
Is the AutoMoveToPosition movement complete. Returns 1 if the servo is still moving. Returns 0 if the servo movement is complete. | |
- BYTE | Return |
MoveToPosition
SetAutoMoveSpeed
SetAutoMoveSpeed | |
Sets the speed of the auto move to position macro. Default speed is 1. | |
- BYTE | Speed |
1=Slowest (Default), 2= Double, 3=Triple, 4=Quadruple | |
- VOID | Return |
SetPosition
SetTrim
