Component: SPI Free (Peripheral CAL)
Revision as of 13:12, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Peripheral CAL
SPI Free component
A low level implementation giving direct access to the CAL
Please click here to download the component source project: FC_Comp_Source_SPI_Free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SPI_Free.fcfx
GetConsoleHandle
GetConsoleHandle
Returns a handle to the console used by this component
- HANDLE Return
GetList
GetList
returns Named property list
- STRING Name
- STRING Return
GetValue
GetValue
Reads Named property Value.
- STRING Name
- STRING Return
Master_Byte
Master_Byte
Sends and receives a data byte
- BYTE DataOut
Master_Init
Master_Init
Initialise the Master
Master_Uninit
Master_Uninit
Uninitialise the Master
SetPrescaler
SetPrescaler
Sets the prescaler value for the clock divider chain
- BYTE Prescaler
SetValue
SetValue
Change Named property to new Value.
- STRING Name
- STRING Value
Slave_Init
Slave_Init
Initialise the Slave
Slave_RxByte
Slave_RxByte
Returns the data received
Slave_TxByte
Slave_TxByte
Sets the data to be transmitted
- BYTE Data
Slave_Uninit
Slave_Uninit
Uninitialise the Slave
Component Enable
SPI Channel selector
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
Prescale
Prescale option selector
Clock Polarity
Clock Phase
Sample Point
Data bit read sample point
