Component: DC Motor (Mechatronics)
Author | Matrix TSL |
Version | 1.2 |
Category | Mechatronics |
DC Motor component
DC Motor that can be driven in one or both directions using digital output pins, PWM or HBRIDGE peripherals.
Please click here to download the component source project: FC_Comp_Source_DCMotor_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DCMotor_2d.fcfx
Break
Break |
Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property. | |
Return |
Coast
Coast |
Turn off power to the motor by setting the pins according to the 'Coast Pattern' property. | |
Return |
Disable
Disable |
Disable the motor output | |
Return |
Enable
Enable |
Enables the motor output | |
Return |
Forwards
Forwards |
Set the motor turning in the forwards direction by setting the pins according to the 'Forwards Pattern' property. | |
Duty |
Sets the motor power for PWM or H-Bridge outputs | |
Return |
GetSimAngle
GetSimAngle |
Gets the angle of the simulated motor shaft in degrees. | |
Return |
Reverse
Reverse |
Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property. | |
Duty |
Return |
