Component: FLASH (CAL) (Misc)
Category Misc
FLASH (CAL) component
CAL - Code Abstraction Layer A low level implementation giving direct access to Flash read and write routines.
Please click here to download the component source project: FC_Comp_Source_FLASH.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_FLASH.fcfx
EraseAll
EraseAll
Erase all flash memory locations on the device.
- BOOL Aux
0=Primary Flash, 1=Aux Flash if available
ErasePage
ErasePage
Erase the minimum amount of flash (usually a page) at the selected address.
- ULONG Address
Start address of page
ReadInstruction
ReadInstruction
Reads a single instruction from the device memory. Loads the result into the Data array.
- ULONG Address
- ULONG Data
WriteInstruction
WriteInstruction
Writes a the minimum number of instructions to the device memory. Takes the values from the data array.
- ULONG Address
- ULONG Data
WriteInstructionRow
WriteInstructionRow
Writes a complete row of instructions to the device memory. Takes the values from the data array.
- ULONG Address
- ULONG Data
Enabled
Type
StartAddress
Bits Per Instruction
Number of bits that can be stored or retreived using a single flash address
Bits Per Value
Number of bits available when initialising the Flash memory.
Min Write Count
Row Instruction Count
Page Instruction Count
Program Counter Increment
Family
