Component: FLASH (CAL) (Misc)
Version | 1.0 |
Category | Misc |
FLASH (CAL) component
CAL - Code Abstraction Layer A low level implementation giving direct access to Flash read and write routines.
Please click here to download the component source project: FC_Comp_Source_FLASH.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_FLASH.fcfx
EraseAll
EraseAll | |
Erase all flash memory locations on the device. | |
- BOOL | Aux |
0=Primary Flash, 1=Aux Flash if available | |
- VOID | Return |
ErasePage
ErasePage | |
Erase the minimum amount of flash (usually a page) at the selected address. | |
- ULONG | Address |
Start address of page | |
- VOID | Return |
ReadInstruction
ReadInstruction | |
Reads a single instruction from the device memory. Loads the result into the Data array. | |
- ULONG | Address |
- ULONG | Data |
- VOID | Return |
WriteInstruction
WriteInstruction | |
Writes a the minimum number of instructions to the device memory. Takes the values from the data array. | |
- ULONG | Address |
- ULONG | Data |
- VOID | Return |
WriteInstructionRow
WriteInstructionRow | |
Writes a complete row of instructions to the device memory. Takes the values from the data array. | |
- ULONG | Address |
- ULONG | Data |
- VOID | Return |
