Component: Kinematics Arm (Mechatronics)
Category Mechatronics
Kinematics Arm component
Demonstrates the principals of kinematics using a user configurable robot arm. Provides full simulation of the movements of the arm and the calculations of the axis positions and rotations.
Please click here to download the component source project: FC_Comp_Source_KinematicsArm.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_KinematicsArm.fcfx
Example program showing a siz axis robot arm with a gripper, controlled using sliders on the 2d panel.
FC6 Icon.png Kinematics Arm Demo
ForwardKinematics
Fc9-comp-macro.png ForwardKinematics
Uses the current joint angles and positions to calculate the XYZ and rotation of each of the subsequent linking joints.
GetJointPosition
Fc9-comp-macro.png GetJointPosition
Gets the XYZ position of the selected joint axis.
Fc9-u8-icon.png - BYTE Axis
Range: 0 to NumAxis where NumAxis = end tool location
Fc9-f32-icon.png - FLOAT XYZ
GetJointRotation
Fc9-comp-macro.png GetJointRotation
Gets the XYZ rotation of the selected joint axis.
Range: 0 to NumAxis where NumAxis = End tool
SetGripper
Fc9-comp-macro.png SetGripper
Open or close the gripper
Fc9-u8-icon.png - BYTE Position
0=Fully Closed, 255=Fully Open
SetJoint
Fc9-comp-macro.png SetJoint
Sets the angle or translation of the specified joint axis.
Range: 0 to NumAxis -1
Angle or dimension
Fc9-bool-icon.png - BOOL Type
0=Absolute, 1=Incremental
Fc9-conn-icon.png Axis
Fc9-type-16-icon.png Number of axis
Fc9-conn-icon.png Axis 0
Fc9-type-16-icon.png Axis Type
Sets the movement type of the axis
Fc9-type-2-icon.png Colour
Specifies the fill colour of the shape
Fc9-conn-icon.png DH Parameters
Fc9-type-15-icon.png d
the distance between the previous x-axis and the current x-axis, along the previous z-axis
Fc9-type-15-icon.png Theta
the angle around the z-axis between the previous x-axis and the current x-axis
Fc9-type-15-icon.png a / r
the length of the common normal, which is the distance between the previous z-axis and the current z-axis
Fc9-type-15-icon.png alpha
the angle around the common normal to between the previous z-axis and current z-axis
Fc9-conn-icon.png Axis 1
Fc9-conn-icon.png Axis 2
Fc9-conn-icon.png Axis 3
Fc9-conn-icon.png Axis 4
Fc9-conn-icon.png Axis 5
Fc9-conn-icon.png Gripper
Fc9-type-7-icon.png Show Gripper
Fc9-type-1-icon.png Colour
Fc9-conn-icon.png Link Mechanics
Fc9-type-7-icon.png Show Links
Determines if the links between axis are shown.
Fc9-type-2-icon.png Link Colour
