Component: SysBlocks (E-blocks 2)
Revision as of 13:15, 15 December 2023 by Wiki bot (talk | contribs)
Category E-blocks 2
SysBlocks component
Please click here for a Sysblocks getting started guide.
More information on the Sysblocks component can be found here.
Here is an example of Sysblocks in action, here we are generating the fourier series.
FC6 Icon.png Sysblocks Fourier Series example
Fc9-comp-macro.png Initialise
Initialise components
LCDClear
Fc9-comp-macro.png LCDClear
LCDWriteString
Fc9-comp-macro.png LCDWriteString
Fc9-u8-icon.png - BYTE X
Fc9-u8-icon.png - BYTE Y
ReadEncoderCounter
Fc9-comp-macro.png ReadEncoderCounter
Reads the current dial counter This is a counter from -32768 to 32767
Range: 0-1
Fc9-s16-icon.png - INT Return
ReadSwitch
Fc9-comp-macro.png ReadSwitch
Samples one of the digital switches
Range: 0-2
ReadSwitches
Fc9-comp-macro.png ReadSwitches
Samples all of the digital switches and returns as a three bit value.
ResetEncoderCounter
Fc9-comp-macro.png ResetEncoderCounter
Resets the encoder dial counter to zero
Range: 0-1
SetDigitalPotWiper
Fc9-comp-macro.png SetDigitalPotWiper
Sets the value of one of the digital potentiometers.
Range: 0-5
Fc9-u16-icon.png - UINT Value
129 Taps Range: 0-128 / 257 Taps Range: 0-256
UsbGetByte
Fc9-comp-macro.png UsbGetByte
Reads the next available byte from the circular buffer, Returns 255 if the buffer is empty.
UsbGetNumberBytes
Fc9-comp-macro.png UsbGetNumberBytes
Returns the number of valid data bytes currently inside the buffer.
UsbLookForValue
Fc9-comp-macro.png UsbLookForValue
Scans the buffer for an array of specific values. Returns 0 if the value is not found. Returns 1 if the value is found.
Fc9-string-icon.png - STRING Value
Value to look for, can be a string or byte array,
Fc9-u8-icon.png - BYTE NumChars
The number of characters you wish to try and match
Fc9-u8-icon.png - BYTE RemoveContent
0=Leave data alone, 1=Remove data from buffer
Fc9-u8-icon.png - BYTE ResetFind
0=Continue the find from the last operation, 1=Start again
UsbSendString
Fc9-comp-macro.png UsbSendString
Sends a string to the USB
String to send
WriteLED
Fc9-comp-macro.png WriteLED
Writes to one of the LEDs as a digital output
Range: 0-2
Fc9-bool-icon.png - BOOL Value
0=Off, 1=On
WriteLEDs
Fc9-comp-macro.png WriteLEDs
Writes to all of the LEDs as digital outputs
Fc9-u8-icon.png - BYTE Values
Range: 0 (All Off) - 7 (All On)
WriteVU
Fc9-comp-macro.png WriteVU
Writes to one of the 8-bit VU meters
0=VU_A, 1=VU_B
Range: 0-255
WriteVUBargraph
Fc9-comp-macro.png WriteVUBargraph
Outputs a bargraph to the VU allowing for level visualiusation.
0 = VU_A, 1=VU_B
Range: 0 - 8
==Component Source Code==
Please click here to download the component source project: FC_Comp_Source_SysBlocks.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SysBlocks.fcfx
