ESP32 Toolchain
Revision as of 10:59, 3 October 2024 by MartinW (talk | contribs)
Prior to installing the ESP32 toolchain, is vital that you update Flowcode components using the Full database option, then reload (Fle > reload) your project or start a new one.
Note: If you are upgrading from a previous version of the ESP32 toolchsain then either rename your project or delect the folder for your project that was created using the previous version of the ESP32 toolchain.
Download the ESP32 toolchain from the Toolchain section of the Flowcode Downloads page.
Save the ESP .msi file to your PC.
Right-click on the file and select install.
Follow the prompts.
The default drive will be on the same drive thart the msi file is saved on.
You can change the drive, but you must leave FC_ESP as the default directory.
When you compile for the first time, it will take considerbly longer then subsequence compiles.
If there is the following erorr message:
'idf.py' is not recognized as an internal or external command
Then either Flowcode project was not reloaded ater full componet database update, or all the components have not beeen updated with the latest Version.
The following message can be ignored:
fatal: not a git repository (or any of the parent directories): .git
