Component: GLCD (KS0108) (Graphical Monochrome)
Revision as of 09:49, 23 July 2024 by Wiki bot (talk | contribs)
Version 1.4
Category Graphical Monochrome
GLCD (KS0108) component
Graphical display component designed to work with the KS0108 type monochrome displays. Also compatible with the newer S6A0107 controller IC displays.
Version information
BPlot
BPlot
- UINT X1
- UINT Y1
ClearDisplay
ClearDisplay
DrawArc
DrawArc
Draws an arc either as an outline or as a filled object.
- UINT X
Center X coordinate
- UINT Y
Center Y coordinate
- UINT Radius
Radius, distance of edge from the centre coordinates
- FLOAT StartAngle
Angle to start drawing, in degrees
- FLOAT EndAngle
Angle to end drawing, in degrees
- UINT Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE Transparent
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Draws a rectangle with rounded corners
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- UINT Radius
- BYTE Transparent
- BYTE Solid
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetBackgroundColour
SetBackgroundColour
- BYTE Pixel_Colour
0=White, 1=Black
SetDisplayOrientation
- BYTE Orientation
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE Pixel_Colour
0=White, 1=Black
Dimensions
Pixel Width
Pixel Height
Controller Count
Speicifies the number of controller IC's built into the display and therefore the number of available chip select pins
Colour
Monochrome
Foreground Color
Background Colour
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
CS1
Chip select to address the first controller IC
CS2
Chip select to address the second controller IC
RS
Data / Instruction register select pin.
RW
Read / write select pin
Enable
Data enable to clock a command or data in or out of the device
Data0
Data Pin 0
Data1
Data Pin 1
Data2
Data Pin 2
Data3
Data Pin 3
Data4
Data Pin 4
Data5
Data Pin 5
Data6
Data Pin 6
Data7
Data Pin 7
Reset
Display reset pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Physical Orientation
Display Delay
Enable Delay
Time in micro seconds to wait before and after toggling the enable pin.
Please click here to download the component source project: FC_Comp_Source_GLCD_KS0108.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_KS0108.fcfx
