| Author
Matrix Ltd
| Version
1.5
| Category
Graphical Monochrome
GLCD (ST7920) component
Graphical display component designed to work with the ST7920 type monochrome displays. Transfers data using an 8-bit/4-bit/SPI digital data bus.
11, 1.4, 03-05-24, BR, Added SPI data mode to the component to work with serial displays
12, 1.4, 20-06-24, BR, Fixed a bug where read SPI pixel data was being repacked incorrectly
13, 1.5, 25-06-24, BR, Added an option to allow the pixel data to be buffer locally
14, 1.5, 25-06-24, BR, Fixed minor bug in pixel buffer addressing
BPlot
BPlot
- UINT
X1
- UINT
Y1
ClearDisplay
ClearDisplay
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetBackgroundColour
SetBackgroundColour
| Specifies the colour of the foreground
- BYTE
PixelColour
| 0=White, 1=Black
SetDisplayOrientation
- BYTE
Orientation
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
| Specifies the colour of the foreground.
- BYTE
PixelColour
| 0=White, 1=Black
Write_Command
Write_Command
- BYTE
Command
Write_Data
Write_Data
- BYTE
data
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
| Number of bits of colour depth available on the display
Red Bit Depth
| Number of bits of Red colour depth on the display
Green Bit Depth
| Number of bits of Green colour depth on the display
Blue Bit Depth
| Number of bits of Blue colour depth on the display
Data Mode
Local Buffer
| The display needs pixels to be assigned in blocks of 8 so for the display to function correctly we need to be able to know the value of pixels on the display to be able to draw without corruption. No - Use the display itself as a pixel buffer Yes - Use the local RAM as a pixel buffer
Reset
| Reset pin
Parrallel Pins
Data0
| Data Pin 0
Data1
| Data Pin 1
Data2
| Data Pin 2
Data3
| Data Pin 3
Data4
| Data Pin 4
Data5
| Data Pin 5
Data6
| Data Pin 6
Data7
| Data Pin 7
RS
| Address pin to tell the display if we are sending commands or data
Enable
| Enable pin used to clock data into the display
RW
| Read Write pin to set the display data mode
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_ST7920.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ST7920.fcfx
