Component: Kinematics Arm (Mechatronics)
Revision as of 11:42, 26 November 2024 by Wiki bot (talk | contribs)
Category Mechatronics
Kinematics Arm component
Demonstrates the principals of kinematics using a user configurable robot arm. Provides full simulation of the movements of the arm and the calculations of the axis positions and rotations.
Example program showing a six axis robot arm with a gripper, controlled using sliders on the 2d panel.
FC6 Icon.png Kinematics Arm Demo
ForwardKinematics
Fc9-comp-macro.png ForwardKinematics
Uses the current joint angles and positions to calculate the XYZ and rotation of each of the subsequent linking joints.
GetJointPosition
Fc9-comp-macro.png GetJointPosition
Gets the XYZ position of the selected joint axis.
Fc9-u8-icon.png - BYTE Axis
Range: 0 to NumAxis-1 where NumAxis-1 = end tool location
Fc9-f32-icon.png - FLOAT XYZ
GetJointRotation
Fc9-comp-macro.png GetJointRotation
Gets the XYZ rotation of the selected joint axis.
SetGripper
Fc9-comp-macro.png SetGripper
Open or close the gripper
Fc9-u8-icon.png - BYTE Position
0=Fully Closed, 255=Fully Open
SetJoint
Fc9-comp-macro.png SetJoint
Sets the angle or translation of the specified joint axis.
Range: 0 to NumAxis -1
Angle or dimension
Fc9-bool-icon.png - BOOL Type
0=Absolute, 1=Incremental
Fc9-conn-icon.png Axis
Fc9-type-16-icon.png Number of axis
Fc9-conn-icon.png Axis 0
Fc9-type-16-icon.png Axis Type
Sets the movement type of the axis
Fc9-type-2-icon.png Colour
Specifies the fill colour of the shape
Fc9-conn-icon.png DH Parameters
Fc9-type-15-icon.png d
the distance between the previous x-axis and the current x-axis, along the previous z-axis
Fc9-type-15-icon.png Theta
the angle around the z-axis between the previous x-axis and the current x-axis
Fc9-type-15-icon.png a / r
the length of the common normal, which is the distance between the previous z-axis and the current z-axis
Fc9-type-15-icon.png alpha
the angle around the common normal to between the previous z-axis and current z-axis
Fc9-conn-icon.png Axis 1
Fc9-conn-icon.png Axis 2
Fc9-conn-icon.png Axis 3
Fc9-conn-icon.png Axis 4
Fc9-conn-icon.png Axis 5
Fc9-conn-icon.png Gripper
Fc9-type-7-icon.png Show Gripper
Fc9-type-1-icon.png Colour
Fc9-conn-icon.png Link Mechanics
Fc9-type-7-icon.png Show Links
Determines if the links between axis are shown.
Fc9-type-2-icon.png Link Colour
Please click here to download the component source project: FC_Comp_Source_KinematicsArm.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_KinematicsArm.fcfx
