| Author
Matrix Ltd
| Version
1.2
| Category
DSP Inputs
Quadrature Generator component
A quadrature generator allowing the generation of two waves Q and I which are b default 90 degrees out of phase from each other. Useful in modulating data.
Please click here to download the component source project: FC_Comp_Source_DSP_Quadrature.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Quadrature.fcfx
Generate
Generate
| Assigns a single value to the specified buffer from the selected waveform data. Each call will read the next value from the waveform and will wrap correctly at the end of the data period.
GenerateArray
GenerateArray
| Fills the output buffer with the selected waveform data. If the buffer is smaller or larger then the waveform data period then the data passed will follow on correctly for subsequent cycles.
GetOffset
GetOffset
| Gets the current phase of the wave as an index from 0 to Num Samples.
- UINT
ModifyAmplitude
ModifyAmplitude
| Allows the amplitude to be adjusted by applying a scaler to the waveform data.
- FLOAT
Scaler
| 1.0 = 100% Default / 0.5 = 50% / 2.0 = 200%
ModifyFrequency
ModifyFrequency
| Sets the frequency output rate by altering the period offset to a new value.
- FLOAT
OffsetRate
| 0.2=F/5 0.5=F/2 1.0=F 1.5=F*1.5 2.0=F*2
ModifyPhaseOffset
ModifyPhaseOffset
| Shifts the output phase by the specified absolute angle in degrees.
- FLOAT
PhaseOffset
| Phase offset in degrees
- BOOL
Absolute
| 0=Relative offset to current o/p 1=Absolute offset to initial o/p
SetOffset
SetOffset
| Sets the current phase of the wave as an index from 0 to Num Samples.
- UINT
Offset
| Current sample of the wave: range 0 to num samples - 1
Buffer Size
| Number of individual elements the buffer can store, default 1.
Buffer Type
| Sets the buffer data type.
Waveform
Amplitude
| Waveform amplitude or volume
Offset
| Waveform DC offset
Calculate Data
| Yes = Allows Sine, Cosine, Noise data to be generated on the fly using a calculation, provides much better resolution at the cost of processing performance. No = Allows Sine, Cosine, Noise data to be generated ahead of run time, provides fixed resolution output but is fast and efficient to generate.
Samples
| Waveform sample count, the number of data points in the stored cyclic wave look up table.
Start Phase Angle
| Waveform phase, the angle in degrees or sample in the wave to start streaming from
Data
| The raw waveform data
Period Offset
| The initial amount that the index increments through the LUT data when reading the stored waveform. 0.2 = Frequency / 5 0.5 = Frequency / 2 1.0 = Original Frequency 1.5 = Frequency * 1.5 2.0 = Frequency * 2
Sample Period
| Degrees per default sample offset period
Frequency Calculation - Reference Only
Sample Rate (hz)
| Allows the sample rate to be entered to allow some basic calculations
Period (s)
| The length of time in seconds that the wave period will cover at the specified sample rate
Frequency (hz)
| The repeat frequency of the wave at the specified sample rate
