Component: Quadrature Generator (DSP Inputs)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category | DSP Inputs |
Quadrature Generator component
A quadrature generator allowing the generation of two waves Q and I which are b default 90 degrees out of phase from each other. Useful in modulating data.
Please click here to download the component source project: FC_Comp_Source_DSP_Quadrature.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Quadrature.fcfx
Generate
GenerateArray
GetOffset
GetOffset | |
Gets the current phase of the wave as an index from 0 to Num Samples. | |
- UINT | Return |
ModifyAmplitude
ModifyAmplitude | |
Allows the amplitude to be adjusted by applying a scaler to the waveform data. | |
- FLOAT | Scaler |
1.0 = 100% Default / 0.5 = 50% / 2.0 = 200% | |
- VOID | Return |
ModifyFrequency
ModifyFrequency | |
Sets the frequency output rate by altering the period offset to a new value. | |
- FLOAT | OffsetRate |
0.2=F/5 0.5=F/2 1.0=F 1.5=F*1.5 2.0=F*2 | |
- VOID | Return |
ModifyPhaseOffset
SetOffset
SetOffset | |
Sets the current phase of the wave as an index from 0 to Num Samples. | |
- UINT | Offset |
Current sample of the wave: range 0 to num samples - 1 | |
- VOID | Return |
