| Author
Matrix Ltd
| Version
1.3
| Category
Peripheral CAL
I2C Free component
Chip Abstraction Layer for Two Wire I2C Communications
Please click here to download the component source project: FC_Comp_Source_I2C_Free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2C_Free.fcfx
GetConsoleHandle
GetConsoleHandle
| Obtains the CAL console handle
- HANDLE
GetList
GetList
| returns Named property List as filter string
- STRING
Name
- STRING
GetValue
GetValue
| Get the Named property value.
- STRING
Name
- STRING
Master_Init
Master_Init
| Initialise the Master
Master_Restart
Master_Restart
| Output a Master Restart sequence
Master_RxByte
Master_RxByte
| Returns a received data byte. Set Last=0 if there is following more Master_RxByte macros Set Last=1 if this is the last Master_RxByte and it is followed with Master_Stop. If Last = 1 the I2C bus will be presented with a 'Nack' condition.
- BYTE
Last
| Range: 0-1 - 0 = Not the last byte to receive, 1 = last byte to receive
- BYTE
Master_Start
Master_Start
| Output a Master Start sequence
Master_Stop
Master_Stop
| Output a Master Stop
Master_TxByte
Master_TxByte
| Send a data byte
- BYTE
Data
- BYTE
Master_Uninit
Master_Uninit
| Uninitialise the Master
SetValue
SetValue
| Change Named property to new Value. If "CHANNEL" the ports will be also updated from the fcd
- STRING
Name
- STRING
Value
| port value as string
Slave_Init
Slave_Init
| Initialise the Slave with the given Address, or range of Addresses. Only address bits that have a corresponding bit set in the Mask will be compared with the incoming bus address.
- BYTE
Address
| 7 Bit Address of this device (Bit 0 is ignored)
- BYTE
Mask
| Bit mask used to compare addresses
Slave_RxByte
Slave_RxByte
| Returns the data received, and sends either Ack or Nak Set parameter Last as: 1=Last=Nak, 0=Ack=More
- BYTE
Last
| Sends Ack if 0, else Nak
- BYTE
Slave_Status
Slave_Status
| Returns the Slave Status. Bit 0 = 1 Indicates address/data byte available in the buffer to read Bit 5 = 1 Indicates that the last byte received or transmitted was data (else address)
- BYTE
Slave_TxByte
Slave_TxByte
| Send a data byte, returns Ack/Nak from Master 0=Ack=More, 1=Nak=Last
- BYTE
Data
- BYTE
Slave_Uninit
Slave_Uninit
| Uninitialise the Slave
| Channel selection
SDA
SCL
Baud Select
| Baud rate option selector
| Baud rate to be used
Slew Rate Control
| Slew Rate Control Enabled or Disabled
SMBus Inputs
| When Enabled input logic thresholds are compliant with SMBus specification
Stop Delay
