Component: Quadrature Generator (DSP Inputs)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 1.2
Category DSP Inputs
Quadrature Generator component
A quadrature generator allowing the generation of two waves Q and I which are b default 90 degrees out of phase from each other. Useful in modulating data.
Please click here to download the component source project: FC_Comp_Source_DSP_Quadrature.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Quadrature.fcfx
Generate
Generate
Assigns a single value to the specified buffer from the selected waveform data. Each call will read the next value from the waveform and will wrap correctly at the end of the data period.
GenerateArray
GenerateArray
Fills the output buffer with the selected waveform data. If the buffer is smaller or larger then the waveform data period then the data passed will follow on correctly for subsequent cycles.
GetOffset
GetOffset
Gets the current phase of the wave as an index from 0 to Num Samples.
ModifyAmplitude
ModifyAmplitude
Allows the amplitude to be adjusted by applying a scaler to the waveform data.
- FLOAT Scaler
1.0 = 100% Default / 0.5 = 50% / 2.0 = 200%
ModifyFrequency
ModifyFrequency
Sets the frequency output rate by altering the period offset to a new value.
- FLOAT OffsetRate
0.2=F/5 0.5=F/2 1.0=F 1.5=F*1.5 2.0=F*2
ModifyPhaseOffset
ModifyPhaseOffset
Shifts the output phase by the specified absolute angle in degrees.
- FLOAT PhaseOffset
Phase offset in degrees
- BOOL Absolute
0=Relative offset to current o/p 1=Absolute offset to initial o/p
SetOffset
SetOffset
Sets the current phase of the wave as an index from 0 to Num Samples.
- UINT Offset
Current sample of the wave: range 0 to num samples - 1
Buffer Size
Buffer Type
Sets the buffer data type.
Waveform
Amplitude
Waveform amplitude or volume
Offset
Waveform DC offset
Calculate Data
Yes = Allows Sine, Cosine, Noise data to be generated on the fly using a calculation, provides much better resolution at the cost of processing performance. No = Allows Sine, Cosine, Noise data to be generated ahead of run time, provides fixed resolution output but is fast and efficient to generate.
Samples
Waveform sample count, the number of data points in the stored cyclic wave look up table.
Start Phase Angle
Waveform phase, the angle in degrees or sample in the wave to start streaming from
Data
The raw waveform data
Period Offset
The initial amount that the index increments through the LUT data when reading the stored waveform. 0.2 = Frequency / 5 0.5 = Frequency / 2 1.0 = Original Frequency 1.5 = Frequency * 1.5 2.0 = Frequency * 2
Sample Period
Degrees per default sample offset period
Frequency Calculation - Reference Only
Sample Rate (hz)
Allows the sample rate to be entered to allow some basic calculations
Period (s)
The length of time in seconds that the wave period will cover at the specified sample rate
Frequency (hz)
The repeat frequency of the wave at the specified sample rate
