API Component.SetSolid
<sidebar>API Contents</sidebar>
Sets whether a component is checked in collision detections
HANDLE Target
- The component to set the state for
BOOL Enabled
- True to enable, false to disable
A solid component can collide with other solid objects on the panel. If an object is not solid, it will be ignored in collision tests.
- Add to a calculation icon:
::Component.SetSolid(target, true)
