API FCD.GetItemValue
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Gets a paths item value from the FCD document
Class hierarchy
FCD
GetItemValue
STRING PathName
The '.' separated path through the FCD to look in
STRING ItemName
The name of the item to read
STRING DefText
A default value to return if the item is not found
The default value for this parameter is: ""
STRING
Returns the paths item value from the FCD document
FCD files are XML files. The PathName must be a list of items, not including the XML root tag of the tags where the XML attribute ItemName is to be located. So to extract the FLASH memory size Pathname="device.memory" and ItemName="bytes".
If the ItemName is not found in the specified location then DefText will be returned instead.
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::FCD.GetItemValue("pathname", "itemname", "deftext")
