API FCD.GetItemValue
<sidebar>API Contents</sidebar> Gets a paths item value from the FCD document
STRING PathName
- The '.' separated path through the FCD to look in
STRING ItemName
- The name of the item to read
STRING DefText
- A default value to return if the item is not found
- The default value for this parameter is: ""
Returns the paths item value from the FCD document
FCD files are XML files. The PathName must be a list of items, not including the XML root tag of the tags where the XML attribute ItemName is to be located. So to extract the FLASH memory size Pathname="device.memory" and ItemName="bytes".
If the ItemName is not found in the specified location then DefText will be returned instead.
- Add to a calculation icon:
result = ::FCD.GetItemValue("pathname", "itemname", "deftext")
