API Component.SetSolid
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Sets whether a component is checked in collision detections
Class hierarchy
Component
SetSolid
HANDLE Target
The component to set the state for
BOOL Enabled
True to enable, false to disable
A solid component can collide with other solid objects on the panel. If an object is not solid, it will be ignored in collision tests.
  • Add to a calculation icon:
    ::Component.SetSolid(target, true)
