API FCD.GetItemValue
Revision as of 21:17, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Gets a paths item value from the FCD document
===Class hierarchy===API
FCD
GetItemValue
STRING PathName
The '.' separated path through the FCD to look in
STRING ItemName
The name of the item to read
STRING DefText
A default value to return if the item is not found
The default value for this parameter is: ""
STRING
Returns the paths item value from the FCD document
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::FCD.GetItemValue("pathname", "itemname", "deftext")
