DSP
Revision as of 10:58, 27 October 2020 by BenR (talk | contribs)
What is DSP
Guitar Distortion
Digital Filtering
Frequency Spectrum Analysis
Baby Monitors
Speed Control
Position Control
Temperature Control
DSP Components
Input
The DSP Input component is used to pass data from another source into the DSP system. This data could come from an analogue source, a external sensor on an SPI or I2C bus, a data file, the possibilities are endless.
Output
The DSP Output component is used to pass data to another source from the DSP system. This data could go to an digital to analogue converter, a external device on an SPI or I2C bus, a data file, the possibilities are endless.
Frequency Generator
The DSP Frequency Generator component is used to pass fixed waveform data into the DSP system. This data is generated by the component depending on the component's various properties. The waveform data is stored into ROM in the embedded target to allow the RAM memory to be retained for the DSP buffers and other system variables.
Delay
The DSP Delay component is used to create an additional buffered delay. Useful for a wide variety of task such as filtering, phase synchronising, echo effects etc.
Scale
The DSP Scale component is used to alter the data in a buffer by allowing a scale or offset to be applied.
Level
The DSP Level component is used to detect peaks, troughs and averages in the data contained in a buffer. This comes with a decay property which allows you to maintain record values long after they have left the contents of the buffer.
Sum
The DSP Sum component is used to allow two buffers to be merged into one using several different techniques such as addition, subtraction, take the max, take the min etc.
Filter
The DSP Filter component is used to attenuate unwanted frequencies from the data in a buffer leaving the buffer full of only the frequencies we are interested in.
FFT
The DSP FFT component is used to convert a time based signal into a frequency based spectrum by dishing out the frequencies present in the buffer into a number of frequency bins.
Component Macros
A typical DSP system will use a timer interrupt macro to maintain a steady rate on which everything happens. The timer interrupt will do things like any analogue sampling and may also call the DSP component functions in order. Based on this methodology we have created two variants of most of the DSP component macros in the form of Function and FunctionArray. These allow two different ways of working with the DSP component. These methods can be mixed and matched as necessary to allow your program to run at the optimum speed and throughput.
Single
The Function type macros allow a single value in the DSP buffer to be processed. Behind the scenes this performs the hardware macro functionality on the next buffer value.
The tick based functions are designed to operate inside the interrupt function at sample rate. This allows your DSP code to utilize more of the system runtime but means you have less time for other functions such as refreshing a display. Because you are only processing a single value in a buffer rather then an entire buffer the function code is much shorter. This also has a second impact that there is a minimal delay in data being held in the buffer before being processed. The location inside the buffer is automatically tracked for you by the master buffer index.
Array
The Array type macros allow the entire DSP buffer to be processed at once. Behind the scenes this involves a loop and we cycle through all of the values in the buffer performing the macro function. Some components such as the DSP FFT only have the Array version of the macro as the FFT calculations can only work with a buffer full of data.
The standard array based functions are designed to process a complete buffer in one operation. Care should be taken that the processing time is no longer then a single interrupt period.
This method gives you free time between interrupts where other functions can be performed such as updating the GUI on a display. The longer the buffers, the more time you get between having to process the trigger code but the downside is that the trigger code will take more time to process.
Combining Single and Array Calls
The single style approach is similar to using the trigger style approach with a buffer size of one so really the design of the system is entirely up to what you feel most comfortable with and what best suits your application.
